New Bathroom
7 Jan 2011
North
Ireland
Hi All
I am currently renovating my bathroom.
I have encountered a problem and wonder is I am correct with this.
My hot water has not isolation valve in the airing cupboard (gravity fed system) but my cold water does.
I have a electric power shower which has a internal pump and hot/cold feed and I want to install a new mixer shower.
I can turn off the cold water OK to amend pipe work to install a shower wall plate but the hot water I cant.
If I turn off the cold water supply to the hot water cylinder run the hot water tap will that reduce the hot water flow and eventually stop the flow so I can go ahead and amend the pipe work?
Then I can install temporay isolation valves to pipes tile my bathroom then do the same again to install the mixer shower.
Would this be a plan of action?
Bung the header tank.
I have a bung kit I bought years ago and works ok.
First thing is fit isolation valve
I have an isolation valve for the water that tops up the cylinder if I close this would this be the same as bunging it?
Loft tanks need a bung or draining.
If you use water it gets replaced by water in tank.
Normally a tap between header tank and cylinder
apologies I meant that I have a isolation at the bottom of the tank that closes the water supply to the cylinder in the airing cupboard - that would by closing this I assume it would have the same effect as bunging it?
Yes, that's the one to close off the hot to the taps.
If it closes properly then you will see the flow from hot taps eventually stop.
Leave the lowest one open while you work as this will allow any water in pipes to exit when you break into the pipework above.
All sorted thanks for everyones advise.
I have old shower removed and pipes amended with a shower wall plate installed now to tile the walls .
