Just moved into my new home (new as in I just bought it). It's a Victorian terraced house which has 10 radiators.
Each radiator has what I believe are called microbore pipes and twin return valves, ie the "in" and "out" pipes are connected to the main valve on one side of the radiator and no valve at the other end. The pipes are very thin copper, I assume 8mm. The radiator valves also have a little cap covering a smaller valve which I believe is to allow the system to be balanced.
The boiler is an old (I think older than me), Glow-Worm 65-80 (that's all it says, nothing else on the case). The system works fine, all radiators are warm, although they do gargle a little when the system is on, sounding as if the pump is pushing the water through every few minutes.
My problem is that running the system for about 6 hours a day (2 in the morning and 4 at night) is costing me about £110 a month in gas. I'm assuming the system isn't very efficient....
Right now I'm looking to get some people round to give me quotes on a new boiler. I cannot, in any way shape or form, afford a complete new system (ie new pipes, rads and boiler). So what I'd like to know is, what is my best port of call?
Should I:
a) get the system cleaned (flushed and inhibited) and balanced and leave it at that
b) get a new boiler for a like for like replacement, and just keep the existing kit
c) something else
The house I'm in has 3 floors, is reasonably well insulated for a house of it's age, in that it has double glazed windows (thin double glazed, but double glazed none the less), fibre glass insulation under the ground floor flooring and in the loft (albeit old insulation) and I have done my best to fill in most of the gaps in the windows which were letting in cold air.
Also, a more general question, which might aid in cutting costs: there are about 4 rooms in the house which we don't use very often, and so they don't need to be as warm as the other rooms, but I had been warned against letting rooms in old houses stay cold, due to condensation etc. Because of the twin valve things on the radiators, and them not being thermostatic, should I leave them all fully open or is it safe to close some of the valves over a little and will that still allow a full flow of water to the rest of the system (as you can guess I have no idea who these old systems work )
Thanks in advance folks
Should I:
c) something else
