"I guess the welds going must be the banging noises that were happening overnight waking everyone up"
It made funny banging noises in the night, when the mains water pressure is highest.
The OP probably looked in the daylight, when the pressure was lower. The radiator was still inflated like a tin Zeppelin then because the spot welds had failed.
PRV not now working properly because it's probably full of crud. See Simond's post above; he has " ... seen this a few times, usually on a Potterton Puma where the expansion relief is blocked."
Its a brand NEW boiler Which would have been flushed , that you seem to think has been over pressured from day one so if PRV was running CRUD would not have a chance to have built up or solidified to stop PRV discharging properly.
It does not matter if pressure was higher at night, PRV on brand NEW boiler should still have opened ASSUMING the filling loop had be previously left open
The PRV should have opened, and it did. To prevent the boiler being overpressurized, it would need to discharge the all the water entering at 3 bar or whatever. The Vaillant figures only give the maximum working pressure, they don't specify the higher test pressure.
The PRV is not sized to discharge mains water when numpty boy leaves the filling loop open. We don't know the mains pressure and do not know what pressure the boiler has been subjected to.
We have all heard PRVS opening on excess pressure they sound like a machine gun going off and this is on just about every boiler even Vaillants and certainly gets peoples attention.
Now rads are tested to 7/8 bar if the rad was not faulty and it was due to boiler being over pressurized . The boiler would have been horrendously noisy and there would be leaks everywhere on it which there clearly isn`t and none of the other rads have gone so this would indicate ONE rad has never been welded up properly from day one
It was a 30/35 year old radiator. You don't know what pressure it was tested to when new. It may have deteriorated but it was still useable.
We don't know what might have happened to the boiler.
So what might have happened? How do you know that the heat exchangers haven't distorted, like the radiator? The secondary PHX is brazed construction, so not likely to spring a leak. The flue ways on the primary HE might be crushed.
But you don't know that and neither do I. Ask Vaillant, they'd know what to look for. Get a Vaillant approved service technician to examine it.
That's exactly what they sound like,a machine gun going off!
Pretty frightening too,I suspect, if your an eighty year old who has only ever had a conventional system and you manage to feck up filling up the system pressure.
I've been on the receiving end of a phone call from said typical octogenarian during such a scenario and I **** myself listening to it over the dog
Its a faulty Radiator. And possibly a faulty prv. The Prv should open at 3 Bar pressure. If it did not than its faulty. The flow rate is irrelevant, when it gets to 3 Bar it should open, thats what its there for. Because its a sealed system if there is any pressure increases it releases the extra pressure.
The flow rate is irrelevant?
You might think so.
So you think you could put a 1/2" PRV on a 1,250 kW boiler?
You'd think that would be OK because you think the flow rate is irrelevant?. Go figure.
You're wrong.
It's a sealed system?
It isn't when connnected to the water mains.
However I have seen two EXVs crack open on new boilers after the filling valve had been left open.
The senario was that the PRV could not let out enough flow to prevent the system pressurising to about 6 Bar at which the EXV will open up at the seams.
