Hi
I have bought a Bosch SMS40T32UK dishwasher, and have connected it to the cold water inlet, and to the waste pipe under the sink, using an adaptor to connect the 19mm pipe coming our of the Bosch to the 38mm sink pipe.
I have ensured that the pipe is raised above the height of the connection to the sink, and have made sure that there are no kinks in the pipe, but when I run a test cycle, it fills up with water, and after a while the "Check Water" light comes on.
I have to then scoop out the water to get it to run again, and it just fills up again with water.
To test if I had made a mistake, I unplugged the waste hose from the sink, popped it into a bowl and ran another cycle - no water came out at all. I can hear the waste pump firing up inside, but nothing comes out.
Looking inside the end of the waste hose supplied there is a black plastic device that fills most of the space - this slots into the adaptor I purchased.
There is a supplied circlular metal clip that fits over the end of the hose, but this doesn't seem to make any difference either.
I checked inside the dishwasher, checked the filter, and the little white plastic protector over the waste exit (under the filter) and all seems ok.
Bosch tell me they can fix it but will charge if it's my fault - I think the dishwasher is faulty, but am not totally sure I haven't done something daft.
Any help is much appreciated!
[/img]
[/img]
