- Joined
- 21 Aug 2015
- Messages
- 7
- Reaction score
- 0
- Country
Hi
We recently moved into a new build which has a bay window in the kitchen.
We purchased 3 wooden venetian blinds for this window.
I am going to need to mount them to the ceiling as they need to clear the door handles.
Its a plasterboard surface and I suspect a lintel of some sort above it but I am not sure how big the gap is between the board and the lintel and I am not sure if the lintel will sit right above where the brackets need to go.
Without knowing exactly what is above the plasterboard, what are my options?
Drill a small hole and see if there is a lintel?
If so, just use a masonry bit and a self tapping screw?
If there is no lintel, should there be joists and I can use three battons between the blinds and the joists?
Thanks!
Thanks!
