New burglar alarm box / old devices?
28 Mar 2006
London
Over the summer I bought a house with a burglar alarm fitted, but we've got no manuals, no codes, no nothing for it. We asked the previous owners, but they said that they never used it!
We got ADT round to look at it and they tried to flog us a contract at £20+ per month for "bells only" which effectively just covered maintenance - seems pretty poor value for money.
The options I'm considering are;
1) Replace the whole lot with a new system (either DIY or other).
2) Find a way of salvaging some of the existing system, but perhaps upgrading certain bits (eg replace the control unit if I don't know the code, adding extra contacts / movement detectors)
3) Remotgage the house and pay ADT's maintenance fees.
Any guidance / suggestions?
Do you know what make / model the alarm is?
If not, put a couple of photos on here and someone may know.
We may be able to tell you how to reset the user code, and also supply you with a user manual.
Thanks. Some photos below;
I know waht that is
just going to wait and see if any one else knows
That is a telecom 670
it has a"brother" the 685
the 685 has a LED dispaly on the keypad
Neither were ever meant to be "bells only", they relied on the signaling, they also do not have an external sounder, since as i said they rely on the signaling.
they are well past the use by date
You will also find that there is an odd resistor configuration in each detector, take my word for it becuse if they have the origonal detectors the plastic goes brittle and they easily break
I would suggest remove the whole lot (cables as well) and either install your own on call another alarm co for a quote
Thanks (even though this isn't the best news!!)
Is there anything I can salvage here? The current system is hard-wired. Can I keep the existing contacts / PIR and just replace the main box / keypad? Or do you really recommend binning the whole lot?
Can you recommend a good supplier for DIY-install alarms? I've seen some at the DIY sheds, but I'm never convinced that you get proper quality-for-money from them...
I don't see any reason why you should have to replace the cabling too providing it is all OK. As for the panel take it to the antiques roadshow might be worth a few quid. Seriiously though install a new panel , bell , contacts and detectors and you should be fine. Don't touch the DIY sheds best bet is to search online or if your not sure or don't feel compotent get someone in to do it.
Breezer it looks similar to the old grainger security systems with the plug on expansions boards for each zone. How old do you think it is. I'd guess 82
Can I keep the existing contacts / PIR and just replace the main box / keypad? ...
I take it you have never seen how they actualy connected them then, twisted cable joints but not soldered.
as ivysystems said it does depend on the condition of the cables, but as i said they used twisted but unsoldered joints which is not good for modern panels, but that said it depends on how who installed, it installed it you may be ok
but you WILL have to run in a cable if you want an external sounder
they must be at leat 20 years old (it also can not be expanded, and comes as is, the 685 could be expnded)
