Can you put up a picture of the offending article, we'll soon tell you whats right and what isn't.
Then it is wrong regardless of what they sayOk, I'll get one at the weekend. But basically it is one single straight copper pipe from the boiler. Straight down about 60cm. Doesn't go into anything. Then a washing machine directly in front of it!
Page 12 on the installation instructions clearly state that this pipe must terminate outside of the building, laundry, garage no matter what it MUST terminate outside , a tundish installation may be used to terminate into an internal drain but the correct pipe work has to be used , no open ends like you have is allowedI have checked and they are gas safe registered!
It's impossible to see if it's dripping!
So are they correct that it can be done the way they've done it in a laundry? For example if there wasn't a washing machine in the way?
I've looked at the Worcester manual but it's a bit vague.
It's the word 'preferably' that they'll probably try and argue.
