New combi boiler. Prv pipe not outside
30 May 2013
West Midlands
Hello
My mother in law has just had a new combi boiler fitted in the laundry room and her prv pipe just drops down from the boiler and stops about 60cm above the floor. That's it. It doesn't go outside or into the condensate pipe using a tundish. Just a straight cut off pipe aimed at the floor behind the washing machine.
I've read one forum where this has happened but it was in a garage rather than a utility room.
Does this seem ok? I'm worried my elderly MIL will be putting clothes in the washing machine and get a face full of steam!
Many thanks for any replies.
28 Oct 2005
Daventry
Unlikely to be a face full of steam but definitely needs correctly terminating outside, as it could cause a small flood, especially if she accidentally leaves the filling loop open
30 May 2013
West Midlands
Thanks guys. I've now read 3 or 4 different things on here where it seems that you can just point it down like this but they are nearly all in a garage. Maybe the installer is treating the room as though it's a garage. I've read though that this pipe should be clearly visible and obviously it's not visible if there's a washing machine in front of it!
6 May 2010
London
It won't have been fitted in accordance with the manufacturer's instructions, so the guarantee won't be valid.
30 May 2013
West Midlands
Thanks, she's having a fair bit of trouble off the installer to be fair. Not for this but for other problems.
It's a Worcester 30cdi. It hasn't kept it's pressure since it was installed. She was warned that the flush may cause a few problems to her under floor piping and that if it did they may have to fit some above floor piping.
So, because of the constant pressure drop she got a quote from them to have 3 new radiators and new piping to them.
Day comes for them to fit and they run in to problems, 1st new rad in, new pipes, doesn't get hot at all. Said they may have to try connecting back to old pipes (wtf). Asl long as pressure didn't drop. Low and behold pressure dropped again so they're basically coming back next Monday to re pipe the lot.
Plus I'm unsure if she's agreed to pay even more money as she's very cagey about it when asked. Unreal!
7 Dec 2018
I wouldn't want a pipe that could discharge water like that behind any of my electrical appliances.
30 May 2013
West Midlands
Right. She asked about this pipe today and was told it is fine as it is in the laundry! It is 100% not visible as there's a washer in front of it.
They also told her how it's nothing to worry about and it will never go off.
Sounds like fobbing her off to me!
I've a feeling when it's serviced they may say something!
24 Jan 2021
Hello
my god, who fitted this? A GasSafe engineer or a cowboy ?
24 Jan 2021
It’s just wrong. full stop.
Any overflow needs to be visible, be it a toilet with an external overflow (used to be like this) or a boiler or a pressurised hot water tank or whatever. It’s a safety feature and dripping is showing you there’s a safety issue
if you can’t see it dripping, you can’t see the problem.
30 May 2013
West Midlands
I have checked and they are gas safe registered!
It's impossible to see if it's dripping!
So are they correct that it can be done the way they've done it in a laundry? For example if there wasn't a washing machine in the way?
I've looked at the Worcester manual but it's a bit vague.
