Having a bit of a rethink about our current heating system. The boiler looked like it was on its last legs and the existing thermal store was starting to leak around the immersion/thermostat/pipework.
Initial plan was to scrap the thermal store and existing Potterton Prima F50 and replace with a Broag 28kw combi boiler. We only use hot water really for showers and washing up so this seemed to make sense.
Had quotes for around £1600 for the boiler, flush and installation which is bearable but having just repaired the Prima PCB, the boiler is working perfectly.
You can get a vented Albion 170L Thermal Store cylinder for around £850 delivered and its within the scope of a competent DIY'er to install so I had a rethink.
Pro's of a Combi :
Instant hot water on demand
Probably more economical than a thermal store
Gain airing cupboard space
Cons of a Combi:
Around 11L/min with a 28kw boiler, at some point we may need 2 showers operating at the same time.
More things to go wrong with it.
When it does go wrong, you lose heating plus hot water
Higher installation cost (and new outside gas pipe as we have 15mm at the moment).
Pros of a Thermal Store:
Instant hot water (if the tank is up to temperature)
30L/min water flow
Faster central heating heat up time
Diy installation possible
Backup immersion heater in case of boiler failure
Half the price of a new install
Cheaper servicing than an unvented system
If the boiler fails then a system boiler is simpler and cheaper to replace than a combi boiler.
Cons of a Thermal Store:
Less efficient as you have to keep the tank heated at 80+C so heat losses come into effect (although these are lost into the house so nothing really lost in the winter).
Lose space in airing cupboard
Three times the inhibitor required
Soooooo ..... a bit torn between the two. I'd like a combi but don't want the messing about boiling kettles of water to wash in if it fails. On a serious budget as well as I'm not getting into debt and will only spend what we have saved up. I'm quite happy to install a new cylinder - plumbing doesn't bother me in the slightest.
What are eveyone elses opinions on the above ?
Ta
Dom
Pro's of a Combi :
Cons of a Combi:
30L/min water flow
Ta
Dom
