I'm having Solar PV installed in the next few months, at the same time we need a new boiler.
I'm looking at the DHW flow rate is important as i like a powerful shower as possible, so i'm thinking of the Vaillant EcoTec Plus 938. The property has 2 bathrooms, water pressure is not a problem (extremely high).
With the Solar PV i'm thinking of using the excess power generated to heat the water in a thermal store using an immersion. Then using the thermal store to pre-heat the water before it goes into the combi, with the aim of increasing hot water flow and reducing gas use. There will be a blending valve in front of the combi to stop the water going in too hot. I have some questions:
1) Is this a good idea (is it normal??)
2) What type of thermal store do i need? Indirect Vented with a heat exchanger?
3) Any makes and model recommendations of thermal store?
Thanks,
Elliot
Thanks,
Elliot
