New Dewalt XR Drills
gbu
4 Nov 2011
London
I have seen some of the dewalt XR drills at Screwfix and although the batteries are much better the Torque seems to be a lot less then the 'cheaper' drills.
I know you should always go for the Li-Ion batts over Ni-Cd but are you paying just for battery life compared to work rate of a drill.
The Torque spec for the more expensive XR drill is 35Nm
and the Torque for the cheaper Ni-Cd is 44Nm
So is the extra money being spent on battery life alone?
extra nm is gained by lower gearing perhaps the speed will be more useful overall
You are Paying for a far superior power unit all round.
It is not just the battery life but the whole convenience of the battery and battery charging that is tuned to professional use.
Thanks for the replies :)
the thing i cant seem to decide on is wehther i get a cheaper ni-cd with higher torque or a more expensive Li-Ion.
I'm a plumber so although i do have to drill sometimes pipe brackets, radiators etc its not a big part of my job and sometimes can go a month without using a drill as im also a bit old fashioned and use a screwdriver rather then get the drill out everytime i come across something that needs to be unscrewed lol
So with that in mind would i really benefit having a battery life and performance that would take ages to run down over power as i need it in short periods?
i do understand the need for decent batteries but as i said its not a daily part of my working life using drills and when i do its seldom for more then an hour or so at a time.
i would go for the lithium 1 then,afaik they do not have a memory on the batteries,so having a ni-cd(could)end up been a tad expensive to you in the long run.
if you don't use the drill all the time, what you will find with ni-cad batteries is that they go flat even if you don't use them. Li batteries last longer and re-charge quicker.
+1 vote for get a bosch-blue drill
what do you want the drill for? drilling into wall for putting rawl plug in or using as a screwdriver?
Didn't see the point in the new XR range. I have the XRP 55Nm drill, don't use it much as its my backup. I have the 80Nm Makita BHP451. The extra torque is great, saves me getting the impact driver out a lot, using it less and less these days as it makes a right racket!
Yea, but it keeps the nosey parkers away from you. Makes you sound like someone not to be messed with. :)
