New double light switch problems
If you can confirm the Lives are on the same circuit and the neutrals of the relevant lights are also on the same circuit, then it MAY be possible to use one of the Lives only and safely seal off the other one.
Not ideal but May be possible.
A better solution would be to fit 2 one gang versions side by side.
Thanks, they are on the same circuit, I will double check in the morning, cheers for the advise much apperciated.
Why do people buy these weird switches..
A much more pertinent question would be why do people by any switches at all, thinking that it'll be perfectly OK for them to fiddle with their electrics when they KNOW that they don't have a clue how it works?
It's a 2221E, so it is, in effect a 2-gang switch, it just has the COMs linked inside it.
But IMO this is still the most pressing question outstanding, and it dwarfs all the others:
So you're planning to do home automation and you can't figure out a switch? :/
And said i said before you act all sumg and smart I have already got most of the light switches changd and working on automation with out a probem, just stumpped with this one switch.
Im very greatful for all the people who helped with this but there is no for people to be jack a$$es. like the above.
And you don't think that being stumped by a 2-gang switch which came with a diagram to show you how to wire it indicates a huge gap in your basic knowledge and understanding?
You are incompetent and ignorant, and aside from pandering to the pathetic unwillingness of so many people to be honest lest the truth offends there's no reason not to say so.
"And you don't think that being stumped by a 2-gang switch which came with a diagram to show you how to wire it indicates a huge gap in your basic knowledge and understanding?"
If you bothered to read my orginal post I was confused due have four wires and only 3 holes..... can you count past 3? Why have you bothed to reply to any of this when you have done is act like an ass?
"You are incompetent and ignorant?"
Fine if being grateful is that, and asking question to get a second option is that, There’s only one fool here and he's turn this topic into flames, really what is the point? And secondly seriously you could do with taking your head out of your ass and looking around once every so often you obliviously a petty little man how spends far too much time on the internet.
So you have a switch wired like this:
and a new switch to fit with instructions like this:
and you claim that you do actually know all about it, and how a light switch is wired, i.e. you are not ignorant, and that you're competent at doing electrical installation work, but you couldn't understand how to fit the new switch?
And that questions like
Is there any way of wiring the new light switch in?
is com the live wire? So I would I connect 1 of the wire in com to L on the new socket and tape the other one and two black ones into 1 and 2?
Ok thanks, theres not way of getting it working then :)?
is the wire currently in com (the red wires) my live wire and black wires the lines?
do show that you are knowledgeable and competent but just wanted a second opinion?
I think not.
The only person I see making flame posts here is you.
Nobody else has insulted anybody.
So when I made factual observations about you, you decided that was a reasoned response?
Like I said - you're the only one flaming in this topic.
