- Joined
- 11 Dec 2007
- Messages
- 426
- Reaction score
- 6
- Country
We got some rads delivered & new valves also. These Drayton valves: http://www.screwfix.com/p/drayton-trv4-white-chrome-trv-15mm-angled-l-s/34362?_requestid=22215 In case the link isn't allowed it's "Drayton TRV4 White & Chrome TRV 15mm Angled & L/S".
Plumber came out yesterday & changed one radiator & replaced the valves for that.
Then for the other 2 rads (that are already off the wall & will be getting changed) he just replaced the valves so he didn't have to do it midweek when he's out finishing the job.
Anyway he didn't put the actual TRV on to begin with. He put something else on, but it ended up leaking when we turned the heating on which he said shouldn't happen as you're supposed to be able to put whatever it was on there so you can decorate & not dirty up the TRV.
So he put the TRV on there & all appeared good.
But a few hours later the TRVs started leaking out of where it would connect in to the radiator. I wasn't at the house at the time but my wife & the plasterer there managed to stop it. When i got home the boiler pressure was at 0 so maybe that's what stopped it. Either way i did it back up to 1.25bar & turned heating on - no problems.
Get up this morning & again both TRVs are leaking out from where the pipe work would connect to the rad.
My wife called the plumber about it as it was initially leaking yesterday & told him the one in the hall was leaking but the other one she said was just a bout wet & wasn't sure if that was properly leaking or not (it is, but not as bad).
The plumber told her the valves are faulty & shouldn't be doing that & we should get in replacements so he can fit them when he lands midweek to fit the rads.
So thanks if you've read everything so far....
Q1: Is it normal for them to leak like this or not? It's not like a full flowing tap but it is leaking.
Q2: Chances of both valves being faulty would surely be very slim would it not?
Q3: So what valves would you buy in?
Q4: Additional pointer: We have no blanking cap on the end that would connect in to the rad. Does this make a difference? Should you be able to NOT have one there & expect no leaks or do you NEED a blanking cap fitted?
