New French doors handle stiff to open and shut
2 Jan 2019
Recently had new French doors fitted. Was previously a tilt and slide. Had pvc put in. French doors with side panels. It looks so much better and modern. However the guys installing had a nightmare as the opening was wonky. But it looks brilliant and you wouldn't tell it wasn't straight forward
However the door seems to me to require a bit of strength to lock and unlock as in pulling the handle fully up and fully down. The kids can't do it. That maybe a bonus haha I have however worked out if I pull at the same time it seems easier. I've greased the locking pins that come out up but it's no better. I noticed from the outside until the handle is pulled all the way up the door at the top sticks out a little. If I push and pull the handle it goes up. Is their anything I could do to make this easier. I've heard hinges can be adjusted using an Alan key to align the doors better? Its something I can put up with but annoying when they're new
Quickest way to see if its an issue that can be solved with ' adjustment '... try each door open , if operating the handles fully up and down is fairly troublesome free then the door sashes will need to be adjusted , either on the hinges ( post a pic of hinges and people can advise how to adjust ) , or potentially the glass will need toe and heeling correctly BUT , if it was fitted by a company , get them back to adjust it , its warranty work. You don't want to invalidate any warranty by trying to do it yourself
Your 100% right it is warranty work. The kids can't open the door. When you close it and lift it up to lock it can be stiff but isn't as bad. To open the door it takes a bit of strength. The kids aren't strong enough which is obviously no good so I have emailed the company. If I don't hear nothing I will ring Monday. It looks when shut as if the top of the door isn't like all the way back so it seems something is misaligned
