I've just installed a new Honeywell Galaxy G2-12 system. It'ds a fairly basic setup ,1 x PIR, 2 x dual tech, 1 x push button, 1 x internal sounder, 1 x external sounder, 1 x keypad.
Looks like everything is wired in correctly (no errors coming up through the keypad, all showing as ok). Sounders are working ok as they activate when doing a walk through test.
When I try to set a full alarm the keypad makes the correct tone and the screen looks like it should in the manual but it never counts down, just stays the same. No groups are set up.
Might be related, when I exit engineer mode, it checks for tampers as it should but just before it exits it shows the following message:
System Modules
Was: 02 Now: 02
Any ideas? Thanks for your help.
System Modules
Was: 02 Now: 02
