R
RedHerring2
I'd appreciate your thoughts/opinions &/or advice.
I'm currently at the below dpc brickwork stage on my current extension.
I have a concern about the new gully for the bathroom (to take bath/shower and whb waste water)
Existing plan shown here:
View media item 25995
Proposed new extension shown here:
View media item 25994
The problem that I have is:
The architect shows waste water from the whb bath/shower discharging into the driveway at the side of the house. In order to avoid loss of width of the driveway &/or damage to pipework I'd prefer to install a new gulley at the rear of the house. Like as shown on this diagram:
View media item 27343
However, to achieve this will mean introducing the flow of waste water against the natural flow of the drain. We are the highest of the drain, so no-one is affected upstream. The manhole brickwork and benching is in good order.
Now I realise this isn't good practice but after more thought I can't really see anything wrong with it, in this instance, although it would mean introducing that waste water higher than the invert level, which again is not good practice. It is only the waste water from the bath/shower and whb. The WC's are still discharging via the existing stack.
But another concern is that 'cos the drain is only 350mm from the outside of the wall to the centre of the drain run (old salt glaze 110mm) the new plastic pipe from the gulley will run almost directly above the old salt glaze pipe run. Is this acceptable? Are there any regulations governing what is acceptable? I would probably encase the both in concrete.
One of the other options I can see is to provide a new short stack within the new bathroom but I don't fancy this and I would still need to run new pipework above existing pipework, to an extent.
The other option is to run the new bathroom gully into the proposed new manhole but this would require crossing the existing drain, at least a 45 ° bend, then within about 2 metres a further 45 ° bend into the new proposed manhole. Like this:
View media item 27344
The BCO is fully aware of the proximity of the drain to the wall and has not objected to anything. I haven't yet discussed the flow of the new gullies into the existing manhole.
I don't see any problem with the new proposed kitchen gulley and manhole although the new pipework will need more or less a direct drop into the new proposed manhole. I was intending to attempt to create a new manhole using the old, existing salt glaze pipework.[/img]
