Hi I need some help getting my CH on.
I just moved in to a 1970's house with an old floor standing Potterton Kingfisher boiler. The HW seems to be working fine, but not the CH (only 2 rads get warm and I suspect this is may due to convection from the HW as both rads are in rooms directly above boiler.
The boiler is in the kitchen on the ground floor, the room stat (cranked up to 80 to make sure it's on) in the lounge on the 1st floor and the HW cylinder on the 2nd floor.
Only 2 rads are getting warm, and on the remaining 7 cold rads, the inlet pipes are still cold so there's no heat getting to them at all.
- I've sussed out the ancient timer switch, and confirmed it is set to fire both the HW and CH.
- I've bled all the rads once and confirmed they're full of water
- I've confirmed the header tank in the loft for the CH has water in it.
- I can't seem to find a CH pump anywhere (not next to boiler, in loft, garage or HW cylinder)
Any Ideas what I should check next?
is there such thing as a CH system without a pump?
