I have removed a leaking hwc used in a warm air heating system. I am confused about what sort of replacement cylinder I should use? There is only the main cold water storage tank in the attic, no separate f&e tank. The one I removed had no heat exchanger in it, even though it had the usual flow and return connections on the side of the tank as per indirect cylinders. Can anyone suggest what I need to do here please.
Cheers
Cheers
