New inspection chamber (sewer)
16 May 2008
Flintshire
Hi, Is there any problems in using a plastic inspection chamber on a driveway (cars will be driving over) or will I need to build a brick one as my plans state? Also I believe the interconnecting pipes need to be clay and encased in concrete if they are close to surface, would this also apply to the plastic chamber if I were to use one.
Shouldn't be a problem, Use one with the correct loading rate. Wavin, Marley etc make a good range.
If pipes are close to the surface encase them in concrete or better still lower them and add the appropiate rings to the inspection chamber..
Thanks for reply. I'm stuck with the height, because this new inspection chamber feeds into an existing manhole 10ft away. Would you say I need to encase chamber totally in concrete aswell or just beneath lid?
just beneath lid?
Beneath the lid is the access to the drain so you hardly want to put any concrete in there!
Do the sides and base...
