Hi All,
I need some help with my Kitchen
I am refub a kichen and i have made several changes
The last change i wanted to make is the old electrica lcooker unit.
This unit is connected direct from the Consumer Unit Board via a 32 amp breaker and a 4mm cable that comes underground direct to the place where the hob + oven will be placed
For being a single unit this was connected to a cooker controler via a 4mm cable(single cable)
I am replacing that unit for a samsung hob that out put 7.5kw and a single oven that output 3.6 kw
I will be using a 40A cooker controller and the distance between the cooker controller and the location where the cables will be coming out from the wall for the oven+ hob is an L shape measuring 600mm and 500m each leg
I wanted to know if i can use a 40mm cable for the oven and a 60mm cable for the hob and if i can connect these BOTH cablesto this cooker controller
Please let me know if any further info is required
