New night storage radiators
17 Sep 2008
I have two night storage radiators (NSR) already, and I want to get two more in different rooms.
Do they require their own seperate dedicated circuit, or do they just run from the normal circuit with a non-removable plug?
How much should they cost - I have been quoted £550 to fit one NSR and one normal heater (not the quote I asked for).
Would there be any reason for the electrician to have quoted for a heater rather than a second NSR? (I could easily buy and fit a wall-mounted heater with a plug myself).
Storage heaters require a seperate 20A supply to each run back t the fused board via a double pole switch. The electrician may have only quoted for one if you have only one spare way in your economy seven fuse board.
Wouldn't like to comment on the cost as I assume it includes supplying the heaters without knowing about the cable run.
If he didn't quote for what you asked for, ask him for the explanation (or see if he misunderstood your needs). Anyone on here can only guess what the reason was.
PJ
If you or anyone fitted NSR's to the normal ring main(final) by whatever means, you would have 8) :) 24/7 heating and an ENORMOUS bill at the end. As wangerman says they should be on their own dedicated circuit.
