    Dismiss Notice
new paving slabs are wobbly (not compacted)
Discussion in 'Building' started by Hannah Cammock, 14 Jul 2019.
  1. Hannah Cammock
    Hannah Cammock
    14 Jul 2019
    2
    Thanks Received:
    Country:
    Hi. New to the forum and after some advice.
    We’ve had a Indian sandstone patio laid (the house is a new build) by a landscaper. He (the landscaper) put type 1 hardcore down which he compacted. He then laid sharp sand which hasn’t been compacted and placed the patio slabs on top. The patio isn’t finished yet but most of it has been pointed. It was pointed on Thursday. Gone out the garden today for the first time as we weren’t to sure when we could stand on it. The slabs move as you walk on them. Surely this isn’t right? We haven’t paid a penny yet. Any advice would be appreciated. Thanks
  2. Sponsored Links
  3. ^woody^
    ^woody^
    3 Sep 2006
    34,025
    Thanks Received:
    4,618
    West Mids
    Country:
    Those slabs should be laid on a solid sand/cement bed, not just sand.
    • Like Like x 2
  4. Guitarguy
    Guitarguy
    26 Mar 2009
    255
    Thanks Received:
    18
    Wiltshire
    Country:
    I laid mine on a wet mix of 5:1 sand cement mix, tried using a dry mix first but was near impossible to level properly.
    Wet mix will also ensure that the slabs completely adhere to the mortar mix and don’t end up sounding hollow or rocking.
  5. footprints
    footprints
    21 Sep 2011
    4,474
    Thanks Received:
    958
    Country:
    I would go with the wet mix too. If you know the maker of the slabs give them a ring and ask for confirmation, then you can speak to your builder with some authority.
  6. ivixor
    ivixor
    4 Feb 2010
    438
    Thanks Received:
    50
    Cambridgeshire
    Country:
    If the sand had been compacted and screeded level, it would have probably been alright. Butv with uncompacted sand, might as well try and lay a patio on the beach.
  7. Ian H
    Ian H
    14 Sep 2010
    7,037
    Thanks Received:
    859
    Rochdale
    Country:
    As said, they should be on a minimum 50mm thick wet mix of sand and cement.
  8. John D v2.0
    John D v2.0
    26 Aug 2016
    6,371
    Thanks Received:
    883
    Country:
    Imagine getting a quote when the tide is in, then when they turn up to start and the tide is out again:LOL:definitely make a loss on that job
  9. Sponsored Links
  10. Hannah Cammock
    Hannah Cammock
    14 Jul 2019
    2
    Thanks Received:
    Country:
    Thanks for the replies guys. He is demanding full payment. The slabs actually rock back and forth!
  11. ^woody^
    ^woody^
    3 Sep 2006
    34,025
    Thanks Received:
    4,618
    West Mids
    Country:
    Tell him you are more into classical patios not rock
  12. geraldthehamster
    geraldthehamster
    7 Feb 2010
    2,973
    Thanks Received:
    320
    Country:
    • Like Like x 1
  13. John D v2.0
    John D v2.0
    26 Aug 2016
    6,371
    Thanks Received:
    883
    Country:
    Well if he doesn't care about fairness or his reputation then i suppose logically getting full payment for no extra work is better than redoing the work properly for the same money. Maybe he thinks it's worth a try.
    Make sure if you pay for anything it's the materials only and then offer to pay the rest for him to redo it properly or ask if he prefers you to pay someone else to do that part
  14. pilsbury
    pilsbury
    21 Oct 2014
    1,548
    Thanks Received:
    197
    West Midlands
    Country:
    If it rocks within a week then imagine what it will be like in a year.
  15. Kenn7
    Kenn7
    22 Jan 2016
    13
    Thanks Received:
    Country:
    Did you ask for them to be laid dry, or did they advertise themselves as specialising a dry lay? If not it's reasonable to expect cement to have been used; in either case the slabs should be firm. I believe you have a good case for not paying for their labour until the work is completed to an acceptable standard. Make it clear in writing if you pay for any of the material and don't let them be taken away. Wet lay will give a good finish, but I've always used a very weak semi dry mix myself because it's easier to handle, almost as easy to level the slabs, just as durable, and much easier to pulls up when the time comes. I have laid a rumbled block drive dry, but I would not recommend it. I thoroughly compacted a good layer of sharp sand on top of a thick layer of quarry waste, and in 10 years it has never subsided, but it's terrible for weeds and ants.
  16. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
