- Joined
- 28 Nov 2019
- Messages
- 97
- Reaction score
- 0
- Country
Hi all.
I swapped an old single wall for a double wall radiator. I read that you measure radiators from the side, not the valves. I could have sworn that it was 1200mm (it certainly was not 1149mm) but the new one is also 1200mm but obviously looks too large.
The valves that came with the Drayton RT212 look a little too long (looks like 1cm to play with on each valve), could I replace with really short valve tails?
The pipes leak when the pressure is turned up. How do I fix this? What have I done wrong?
Thanks.
Thanks.
