I’m planning the installation of a shower room and am after some advice on the best wall structure – the main factor is overall quality and to avoid future problems related to moisture. space is a bit limited but I can work around it if it improves the structure significantly.
The plan is to have tiled walls, on three sides, then a glass door at the front.
The two existing walls are plastered brickwork and I need to create the third wall. I plan to make this from timber and clad with plasterboard, skim it, apply a tanking solution (unsure what product), then tile. Is this advisable? Or am I better to use something different to plasterboard?
How about the existing plastered walls? Should I tile apply the tanking solution straight onto the painted plaster work then tile? Or should I over clad then tank, then tile?
Any advice appreciated.
