L
Leofric
The point is what precautions do you take where drains are near the surface , cover with whatBC ask for (not demand) 300mm cover.
The point is what precautions do you take where drains are near the surface , cover with what![]()
Concrete each side of the drain in extreme cases.The point is what precautions do you take where drains are near the surface
Adjacent matching material, obvs.cover with what
It does not need to be a physical cover, but can be a warning marker of some sort.The point is what precautions do you take where drains are near the surface , cover with what![]()
somebody has said it at last.Concrete each side of the drain in extreme cases.
so does that mean if the adjacent material is soil you can just cover the drain with a bit of soilAdjacent matching material, obvs.
yes,I know that.t depends what your protecting it from.
wonder if Action Joe now knows what to do or if he will be painting the soil over the drainit could be simply paint or soil.
wonder if Action Joe now knows what to do or if he will be painting the soil over the drain![]()
I forgot to say my occupation is a soil painter, so I know how to do this bit
I wasn't aware you were so desperate for an answer, else I would have said sooner - sorry.somebody has said it at last
Or a lot of soil if you wish. And that's the beauty of soil.so does that mean if the adjacent material is soil you can just cover the drain with a bit of soil
but you won't be able to use a lot of soil if there isn't much depth of cover , that is the pointOr a lot of soil if you wish.
My book says don't always take a lot of notice of comments on internet forumsWould the drain still work if he did that? What does your book say?
My book says don't always take a lot of notice of comments on internet forums![]()
Cover it with astro turf.![]()
You can build the soil up as high as you like. That's what you do in soil areas.but you won't be able to use a lot of soil if there isn't much depth of cover , that is the point![]()
