I've just bought a new spot light to replace a loop in pendent. The spot has L N and E. Whats the best way to connect the switch cable? Is there a bit I can buy that replaces the loop in fixture?
The new spots are a bit on the small side so I don't have enough room to keep the existing fitting, and a round junction box won't fit through the hole in the plasterboard.
Is there a slimmer fitting that would do the same job as the junction box, would a choc box fitting for example be acceptable?
You can now buy little plastic boxes of varying sizes with cord grips for flex into which you put your own terminal strip. These are acceptable as when closed the connections are inaccesible, and for light fitting flexes the cord grip prevents strain on the terms.
Probably a complete thicko question; can you use a terminal block to do this - so do away with the ceiling rose and make all the connections using a terminal block, which would then either sit in the light housing or be pushed into the ceiling? If you did, would you use a 5amp or 15 amp block?
