OK, so you need to keep SWMBO happy!
If you install a Honeywell CM900 series programmable thermostat for the central heating, you only need a single channel timer for the hot water side. This can go where the existing programmer is. I would suggest a Drayton Tempus 1 or Tempus 7. The Drayton LP111 or LP711 would also be suitable. The difference between the Tempus and LP versions is that the Tempus has a "Boost" button, which allows you to put the water on for an hour.
I know your main aim, at the moment is to get the system working but, when you decide to change the programmer, it would be worth rewiring the terminal block as per the "standard" scheme. This will make it much easier for any engineer to follow.
Come back to this topic when you decide to make the change, we will then have all the "history" and wiring data.
