New Taps Advice
10 Jul 2016
Just had new taps fitted and have noticed that the left tap seems to be dribbling all over the place. Would an aerator fix this? I have attached a link for a video. Many thanks.
Does it sort it self out when you put your finger over the spout and then remove ? This just has the tendency to change the flow pattern through the filter/ gauze in the spout for the duaration of that flow(i.e. Not a fix) but just lets you know it's sortable!!
Then what I'd do is undo with spanner and check for any debris , also some taps can have many gauzes in spout ( different sizes) try playing about if that's the case removing 1 or 2??!
Put a aerator in or even add a piece of gauze which you can self cut , just to change flow pattern.
Just a case of elimination, Beware-water always bites you on your ARS!!
Hard to tell from film but i would suggest taking the aerator off and checking for debris post intallation. Chances are there's just a bit of carp in it.
Take out indice/aerator and rinse it, upside down, under the other tap. Blow through it a couple of times also. If problem persists use a bright light and a needle to clear holes and push any tiny particles out. After that... get new aerator.
