Our toilet float valve recent broke and didn't stop filling the cistern. I've tried to replace it with a bottom entry fill valve from screwfix:
https://www.screwfix.com/p/fluidmaster-bottom-entry-brass-shank-fill-valve/47792
It fits the cistern but I can't stop the joint connecting the bottom of the valve to the existing copper pipe and brass fitting.
I've tried using a fibre washer in the brass connector (nut at top of photo with yellow arrow) and also a rubber washer and tightened it down but both leak water. I also tried PTFE tape around the thread but that didn't make an difference.
I have considered replacing the brass connector where the washer sits and is compressed by the brass threaded pipe in case this is pitted on worn.
Any hints or tips would be appreciated.
Martin
Martin
