I now have a cold fill machine replacing hot and cold. I have fitted a blank to what I think is hot feed but no water comes through the cold. First use of the washing machine resulted in washing coming out hot so I may have the wrong supply blanked off. My two feeds are controlled by flimsy blue plastic valve switches. The one to what must be the cold feed is broken off so I cannot switch it on after switching the blank over. Do I need to have new section of cold feed pipe with valve fitted, or is there another ay of turning the cold feed on. Maybe I just continue using hot feed water?
