Newly installed shower mixer
2 Aug 2007
Berkshire
Hi all,
I have just had a mixer shower set replacing my taps (bath). I would like to use this as a shower as the water comes out at a good rate
My hot water comes from a combi. When I use the hot water tap, the pressure is fine. When I put the cold on, the flow slows down alot and doesn't get any cooler. If I switch it all off and use the cold in my basin, it is alot warmer than ever has been.
I think the problem is that my cold water is coming from the roof tank and thus the water is not as pressurised as coming from the boiler which has a pump.
a. Am I correct in my thinking?
b. What can I do about it?
Your advice will be very much appreciated
I would look at taking the tank out of the loop. Turn off, drain down. Link mains inlet to cold outlet.
If you are in a flat make sure you are not affecting other residents.
I guessed that I need to somehow point the upstairs cold to the mains. Didn't even occur to me to get rid of the ceiling tank..
Thanks....Great idea...
