Next sizes up and where to purchase?
17 May 2008
GUE
I have a small Stanley socket set which goes up to a half inch socket. I need to remove 3 bolts which are housed in a tight space. They are impossible to get at with normal spanners so need either a socket or a box spanner.
The half inch is just too small to fit. I am assuming that I need a slightly larger size - even if that is a metric size.
Can someone tell me what the next size from half inch is (in metric and imperial) I am guessing 9/16ths and 13mm??
Next question is where I can purchase them without having to buy another full socket set.
Thanks people.
B
There's a very good chance indeed that you need a 14mm socket - very common! Failing that, 9/16".
Individuals are available from Laser Tools, courtesy motor factors.
This will be for the blade carrying shoe, no doubt?
John :)
Thanks BM.
Actually it's for the 3 bolts holding the engine/engine mount to both housings. The bolts are recessed in moulded hard plastic holes so only room to get a socket or box spanner in.
Will have a look at Laser.
Things can never be easy can they?...
Just measured my socket set and they are 1/4 inch fittings.
Laser don't do them...
I assume I need to buy a converter (1/4 inch female to 3/8ths male?)
Where do I get one? Fleabay (please say there's an alternative)
A converter probably exists somewhere, but really you are expecting 3/8th gear to be turned by smaller stuff, that will overstress ratchets, drive bars et al.
How about a Kamasa socket set as a bit of an investment?
John :)
In all honesty BM, the set I have was bought years ago and very rarely gets used. In fact, it's so long ago, I can't even remember why I bought it but I suspect it was for some IKEA shelving. It comes in handy for hard to budge screws and for the odd task where bolts are fitted to appliances etc.
I don't own a car and I rarely use bolts as a construction method so wouldn't really get the use out of a new socket set.
Appreciate the idea but it's not really an option.
I do realise the reasoning you listed about the sizing is very sound.
Thanks,
B
Thanks gram.
Bought a cheap box spanner for this task but it's proving a bu**er. Got one of the 3 bolts out and, as I type, the other two (which I couldn't budge yeterday) have been sitting in WD-40 overnight. I am going to give them another go today. If that doesn't work, I'll look to use your suggestion.
Cheers.
B
UPDATE
Well chaps, after much swearing and sweating, the box spanner did the job (albeit I broke a cheap screwdriver turning the last bolt...) Okay, cost me £3 for the boxy but the job is done.
Thank feck for that.
Thanks for all your help and suggestions.
Kind Regards,
B
