I've got my DIS assessment this week, and am after some pointers as to what i should watch out for with the work i've done and any other tips regarding the assessment.
I've done the following work on my own and another house after speaking to LABC and NIC to check if these jobs are ok. (LABC has said to keep work to new circuits, then if i for some reason fail the assessment i should either notify them again to come and check it or simply remove the new works....i don't plan on failing ;/ )
Job 1: is a another house (Parents) they had already had a CU change done last year (which looks messy inside) so decided to add another small CU for some outdoor supplies. I've fitted some IP66 sockets via 4mm3cSWA in a radial and have also fitted a bulk head light next to a gate in 1.5mm3cSWA via a timer/switch and photocell. Any pitfalls i should look out for.
Job 2: My house, just moved in, it already had a reasonbly new CU, so have simply added a new circuit via 2.5 t/e to a s/wfused spur (all inside the cupboard the CU is in) for an electric fire.
I've also tested and checked the upstairs sockets so he can check me on testing a ring.
