I purchased a Nissan almera from a mate 2 years ago and its been working relatively well, not really had any issues, apart from a faint "vacuum" type noise which I was told by mechanic was the fuel pump. However recently, I've noticed the gear stick vibrates, or moves intermittently when i'm on the motorway (vibrates and the movements can be upto an inch), sometimes when i'm at a constant speed, and sometimes when I accelerate. At the same time, the car seems to "judder", or "shake" as if i'm in too high a gear for the speed (even though i'm in 5th gear at 60 or 70mph). Sometimes I've noticed its happening in first gear.
Now just to add, the engine management light is on, and when checked, its giving the code 117 (something to do with air flow sensor). not sure if this has anything to do with it. Was last serviced about 11k miles ago.
finally, I've noticed the speedometer dial now shakes/moves when idle, it never did this until recently.
does anyone know what could be causing this issue?
Many thanks in advance.
