- Joined
- 31 Dec 2003
- Messages
- 179
- Reaction score
- 1
- Country
I have recently bought a property with a Grant 90 combi boiler which heated the rads OK but not the hot water. The previous owner of the house paid for a plumber to make some repairs which included replacing the diaphragm in the boiler and a couple of other things, including fitting a new pressure vessel, he claimed to have done but I'm not sure he actually did.
The cold supply has plenty of pressure and we have hot radiators and hot water although the hot water pressure is very low and it takes ages to fill the bath. I suspect the problem is associated with the fact that the system pressure keeps dropping and I have to keep re-pressurising it. Diagnosis is not helped by the fact that the house is frequently unoccupied but the heating system is left switched to constant with the room stat turned down to 5C to prevent freezing. When occupied - most weekends - it's necessary to repressurise the system and then I have to keep doing it although if I forget to check it doesn't actually seem to make any difference to the way the system works.
I have contacted Grants and they have suggested the low hot water pressure may be due to lime scale as the house is in a very hard water area and there is no scale prevention system fitted. Their solution was to replace a major pipework component in the boiler as they say it can't be descaled but I'm reluctant to spend money on a possibly doomed project.
Grateful for any clues as to why the boiler keeps losing pressure and why the hot water pressure is so low.
Finally, to repeat, I can't see any evidence of leaks.
Mike C
Mike C
