Evening all,
I'm Installing a basic thermostat system onto my parents 25 year old oil-fired central heating system (no gas as it's N. Ireland). The images below show the oil boiler setup located in the garage:
At the moment, there is no control. At all. Just on-off. As a result, they are heating a large house (25+ radiators) pretty much all the time, which is costing £3k+/yr in oil
I'm planning on installing a couple of Honeywell zone valves (for CH & DHW), controlled by a programmable thermostat. I'll use the zone valve end switches to switch on the boiler & pump. Effectively it'll be an S-Plan system.
Now I'm no plumber, but my dad and I will manage to splice in the two zone valves. What I don't want to do is have to install a boiler bypass etc.
My question is - as there is no pump overrun, can I get away without a bypass? After all, both zone valves will NEVER be closed whilst the boiler/pump are on. They can't be.
If the system is ever updated to include boiler with pump over run, I'll have a bypass put in then.
Cheers
Cheers
