Hi I have the same symptoms as others on this site but my observations are slightly different than others.
My system is a domestic one with a Potterton 50e boiler. The 3 way valve is the (much maligned by most of the engineers on this website)switchmaster. Pump is the Grunfos 15/50 and the thermostat is another switchmaster. Controls are a recently upgraded to (18 months ago) Danfoss FP715si. Not sure if the system is open or closed loop but we have tanks in the loft. Boiler was installed 15 years ago but seems to be ageing well. some periferals have be upgraded over the years
All was working ok until last night and it was pointed out to me that the central heating was not working but we had plenty of hot water. Just what we needed on the coldest night of the winter so far. I did some basic observations and then trawled the net for inspiration. It would appear that the only issue is that the switchmaster 3 port valve is set to heat the hot water only and when i turn it a bit (like i have seen the servicing people do)to prompt it to go to the central heating part it does one revolution, past the central heating settings and settles on the hot water bit again before allowing the boiler to start again thus only heating the hot water.
However i noticed that the 3 port switch can be removed from the plumbing and the valve bit beneath is able to be turned to align up to any of the positions. With the synchro motor aligned to hot water and the valve set to heating and hot water the radiators are back on as a temporary measure. The adjustment of the thermostat does not seem to make any impression on the operation of the 3 way switch or anything else. Please help with any advice and experience you may have. Phil
