    Dismiss Notice
no central heating after draining and refilling
Discussion in 'Plumbing and Central Heating' started by stephent123, 18 Sep 2011.
  1. stephent123
    stephent123
    18 Sep 2011
    10
    Thanks Received:
    Monmouthshire
    Country:
    I have a powermax 155x (vented)
    I installed some TRV's to some downstairs rads today. Drained the system and installed them, all seemed great. Refilled the system and bled all rads.
    Tried to turn the CH on and it didnt work. The light is on on the programmer, the CH pipe to the pump is hot (to and after the pump) and I can still get hot water by turing the HW to constant. I cant get it using the programmer on its own.
    I hope its not the programmer thats shot as i replaced it around 18 months ago. But surely draining the system wouldnt affect this?
    The thermostat light will not come on downstairs. It clicks, but no light. As it clicks i am guessing its still working.
    Any advice would be really helpful, as I am totally stuck. I am sure its something fairly simple that i have or havent done.
  2. Sponsored Links
  3. 45yearsagasman
    45yearsagasman
    14 Mar 2010
    6,087
    Thanks Received:
    1,091
    Norfolk
    Country:
    There is a cold start stat that prevents the ch working until the stored water temp gets to approx 65 deg C.
  4. stephent123
    stephent123
    18 Sep 2011
    10
    Thanks Received:
    Monmouthshire
    Country:
    Its not that, the water has heated up sufficiently.
    could an airlock prevent the light from coming on on the thermostat?
  5. flameport
    flameport
    10 Mar 2007
    9,547
    Thanks Received:
    1,884
    Poole, Dorset
    Country:
    No.
    However if the thermostat indicator is not working, this suggests either there is no power reaching the thermostat, or the thermostat itself is broken.
  6. stephent123
    stephent123
    18 Sep 2011
    10
    Thanks Received:
    Monmouthshire
    Country:
    I am sure its the programmer.
  7. Sponsored Links
  8. misterdubya
    misterdubya
    2 Oct 2010
    3,625
    Thanks Received:
    539
    Country:
    Why? Have you tested it?
    If your sure, then bypass it.
  9. stephent123
    stephent123
    18 Sep 2011
    10
    Thanks Received:
    Monmouthshire
    Country:
    How would I bypass it? I am not a plumber by the way. You probably guessed mind lol.
  10. flameport
    flameport
    10 Mar 2007
    9,547
    Thanks Received:
    1,884
    Poole, Dorset
    Country:
    What programmer is it?
    Typically it would be bypassed by switching the power off, removing the programmer from the backplate and installing a wire link between live and the CH ON terminal.
  11. stephent123
    stephent123
    18 Sep 2011
    10
    Thanks Received:
    Monmouthshire
    Country:
    standard built in one.
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
