no drive when clutch pressed
16 Sep 2008
Staffordshire
have a 2000 brava 1.6, we parked the car up and all was fine, clutch has been high for a while. Went to drive car and when you press the clutch pedal and engage a gear your foot can come fully of the clutch pedal and there is np drive? fitted a new clutch today and still no drive.
Is there a way of bleeding the slave cylinder as i can see no resivouir to top up?
any help please need to get car on road a.s.a.p
the clutch slave uses the brake fluid so you`ll need to top that up, and bleeding the system is the same as bleeding brakes, pump the cluch pedal up, hold down whilst someone else opens the bleed nipple on the slave, repeat until cluch pedal feels nice and all the air is out of the system,
