My daughter has just moved into a private landlord property which has very old gas central heating fitted. The boiler is floor mounted in the kitchen and controlled by a RANDAL 103 timer which turns it on or off. There is no Zone Valve fitted to select "Hot Water" only, i.e. if she wants any hot water she has to have the radiators that work blazing hot at the same time.
To add insult to injury there is NO room thermostat fitted to control the house temperature so the boiler just burns constantly unless my daughter turns down the "Boiler Stat," although that doesn't seem very effective in function.
Now my questions. Is it in any way against regulations to have a gas boiler controlled by just the thermostat on the boiler itself. Also is the above heating configuaration in any way against current regulations here in the United Kingdom, or in any way dangerous?
My daughters landlord says it safe and above board to run it in the way I've described. It's costing her most of her wages in winter just to keep the house warm because there is no proper control by thermostat.
Sorry about this long winded post but I thought I'd best give as much info as possible. I hope some member can guide us on this.
Thanks,
John
Thanks,
John
