Hi All,
I have no hot water and have been fault finding & learning from the internet for several hours.
I think Ive narrowed it down to the aqua switch as when the hot tap is turned on, nothing happens on the boiler, no yellow led to indicate ignition and no green led to indicate demand. (my CH is working fine)
I can see from the register list that D22 contains value 0 which backs up the logic that it is a faulty sensor. Ive also read that these can get clogged up over time, my boiler was fitted around 2001 so definitely old enough for it to have become clogged up.
Id rather replace the complete unit rather than taking it apart & cleaning it.
My question is, do I have to drain my system right down, (& lose my inhibitor), or can I just isolate the supply to the sensor & open the hot taps. Would this be sufficient ?
Thanks for any response.
