No Hot water
3 Jan 2008
Buckinghamshire
I wonder if anyone could give me some advice please? I had a new central heating system installed 18 Months ago with a Mega Flo and a couple of days ago the hot water supply stopped working. The radiators are working fine and I have temporarily powered the Mega Flo using an Electric Cable, however this I am sure will be expensive.. I am presuming the problem is likely to be the thermostat, however wouldnt know where to start..
My question is.. is the problem likely to be thermostat?
How easy a job does it sound?
Appreciate any help..
Regards
Neil Moy
Hi Kevin, Where would I fing the 2 port valve.. sorry if this is a stupid question!!!
Thanks for your response.
Cheers
Neil
a couple of days ago the hot water supply stopped working. The radiators are working fine and I have temporarily powered the Mega Flo using an Electric Cable...I am presuming the problem is likely to be the thermostat, however wouldnt know where to start.
There are two common causes:-
1. Cylinder thermostat;
2. Motorized valve (not opening or microswitch faulty).
...and two less common ones:-
3. Programmer (faulty or wrongly set);
4. Wiring fault.
To diagnose which component is faulty you need a multimeter and the knowledge to use it.
Likeliness is irrelevant - you need to work through systematically to find the fault.
Pretty easy.
