Central heating works but no hot water, the honeywell 2 port valve doesnt open when water is called for, even if i manually open the valve the water doesnt heat up, how can i check if the valve if goosed, also there is a gate valve fitted between the 2 port valves which has started to leak water and when turned doesnt appear to be doing anything.
thanks
thanks
