no hot water
29 May 2004
hi,
I have a boiler that is working and providing central heating ok but I can get no hot water, just luke warm
The boiler lights to heat the water, the pump works and all the pipes are hot.
I have checked :-
1) The thermostat on the hot water cylinder
2) the immersion heater does give hot water
3) The pressure release value also gives hot water when pushed
4) manually pushing the value to the central heating that then started to heat the radiators
5) There is no air in the radiators
The only think that I think might be the problem is an "air pocket".The pressure release did drip every minute and now doesn't
I am going to drain the central heating system next.
Any other suggestions ?
If you do not know what is wrong with the system, why do you want to drain it. Do you have a reason to believe that draining and refilling will cure the problem? Why do think there is an air pocket. Have you checked the pipe runs for places air could be trapped or just assuming the plumbing ai air locked.
Can you indicate what boiler make and model is, because this would have a big bearing on why the system is not functioning.
hi,
The boiler is a ideal classic RS50 and the water tank a elson silver.
I do not know what is wrong with the system but just hoped that draining the system might work. The only thing that looks wrong is the pressure release value is not dripping every 30 secs as before.
I presume this is a sealed system?.....how did you check the cylinder stat was calibrated correctly?
hi,
Yes its a sealed system. How do I check that the cylinder stat is calibrated correctly?
Jon
