Hi to all,
For the past couple of days I’ve had no lighting downstairs, according to the wife several lights were on at the time including the kitchen and dinning room, and then there was darkness, along with the 5amp fuse being tripped at the breaker.
The first thing I checked with trusty multi-meter was the fuse, which has continuity across when pushed on; I also tested the same fuse on the upstairs lighting, which worked fine, so that discounts the fuse.
Next I tested for 240v from both sides of the fuse socket; again with the use of the multi-meter, with one probe live, the other to ground, all seems ok there as well.
After this I checked continuity from all wall switches to each light fixture, all seems ok there, and there is also voltage at each switch as well.
The fuse itself doesn’t trip at all when the breakers power is on, but still no lighting. At this point I’m completely perplexed, can anyone offer any advice to my lighting problem
Regards,
Russ
Regards,
Russ
