No RF Signal
13 Dec 2014
I finished the installation of my system. Awaiting com-USB before proceeding.
I registered the Ricochet devices all appeared well.
I then left everything powered off overnight - battery out.
Powered it back on, 2 devices, one a PIR and the other is a door senor seem to have problems.
The panel is showing
EXP 1,1 Tamper
No RF SIGNAL 011 PIR
No RF SIGNAL 012 Door sensor
The other two devices are not showing a fault.
If the panel has been powered down, battery removed. Do I have to re-register the devices?
Is EXP 1,1 the keypad?
Merry christmas
RKP = keypad
EXP = Expander
You do not have to re register the devices.
do a walk test first, as this wil wake up all the devices the system sees, and you can walk test the device, put it in walk test, make a brew and then start to test the devices.
make sure the tamper is secured.
If you are still having problems give us a shout and i will go throuh it stepby setp with you, just sorting out a delivery at the moment so be 15 mins to half an hour
Thanks for the speedy response.
I don't have a expander just a keypad.
Oh do I wish I had bought com-USB instead of having to wait. Seriously bad mistake not ordering immediatly.
hi what is on your system at the moment?
wrt you are using -W panel, then the tamper is due to the comissioning link, move it across so its no longer in comissioning mode.
