No soil vent pipe
7 Aug 2011
Just moved into our 1950s bunglalow and I have noticed that there is no soil vent pipe. In the conservatory they have fitted an AAV. Next to the manhole cover there is a downpipe which feeds directly into the manhole so I would presume this will act as somesort of a vent (not the correct thing obviously) but is this OK? We don't have any smell issues, it just concerns me.
The usual trick of Conservatory fitters - drop the vent and AAV it. If there are other houses nearby with vents, you'll probably be OK unless your bungalow is at the head of the drain run - ie. the first one.
The toilet in my workshop goes straight into the ground and about 6 meters straight to the nearest manhole which is for next door’s property and is the end of the line. No vents of any kind. Been like that for at least 35 years.
My only concern would be if the downpipe vents through the eaves and stinks the loft out. Rainwater should only discharge into a combined sewer via a trapped gulley to prevent odour returning via the gutter outlets.
Yes, you are right there Hugh. I will bear that in mind when I redo the guttering and put a trap in the pipe. Thanks.
