I'm having a problem getting a solder ring to attach properly.
I'm new to using solder rings but I took the advice here and practiced a little on some scrap pipe. I clean the pipe, apply flex, heat and end up with a perfect joint - nice neat, even solder appears.
When I do the same thing with the existing pipe I never seem to get any solder appearing out of the sides of the joint no matter how long I heat the pipe. I've tried getting water out of the existing pipe by heating it up and down. When I try using wire solder it just goes brittle and breaks off, which makes me think the temperature may be too high...
What am I doing wrong?
