There was a leak at the feed pipe coming from the cold water tank. So i stopped the feed to the tank and drained the hw cylinder and tank by opening a tap, until both the cylinder and cold water tank were empty.
Fixed the leak, turned on the feed to the cold water tank, tank is full, the cylinder is full.
Turned on the heating, the pipes going to the heat exchanger (flow and return) are both very hot, not a boiler problem then. The vent pipe is very hot until 1 feet above the outlet and to the point where it dissapears through a wall. Turning on the immersion heater doesnt help either to create enough pressure to push the water through, when it reaches 60 degrees it just turns itself off.
There is cold water coming through the cold water taps, good pressure.
But when opening the hot water taps anywhere in the house, theres a bit of dribbling (warm-ish water) then stops, not water at all coming through.
There isnt a motorised valve on the dhw circuit, i looked.
I think there might be an air lock somewhere.
How do I get the water flowing through the how water taps?
I am VERY desperate, please help...need to take a shower.
