Mr Experts,
Near the door in my flat, I got two vertical pipes from ceiling to floor, I think those pipes are filling in water for my flat.
1. Why I got two instead one (both pipes are cool)?
2. Some noise comes from the pipes, the noise happened in random time even nobody uses water in my flat (except the radiators). The noise is so big that I may be waked up when I sleeping. There is a valve in one of the pipes, if I turn the valve off, the noise my be much reduced. Do you think that is OK to turn off the valve?
3. I think it is not hammer. The sound like that when you push air out from you mouth while your tongue is vibrating.
4. Some plumbers came to check (the tank above the ceiling?) but didn't do anything. Anything I can do or ask a plumber to do to stop the noise.
Thanks a lot for your help.
